Hi everyone
I am joining a Column and a wall. And every time, I click on join, the error appears that Cannot cut joined elements. Visually, the walls are not cut by the columns. Why is this problem happening? Is there a solution to this?
Solved by salmanjavaid2000. Go to Solution.
you can try this
or
https://forum.dynamobim.com/t/auto-join-walls-and-columns/1938?page=2
What kind of warning do you have for that wall...copy wall and column to clipboard and past in a blank .rvt which you can post here for checking
Both of these are not working. It gives the same error again and again. I just splitted up the walls and clear the way for columns
If your issue has been solved (one way or the other), post the method and/or accept solution
I don't have any issue joining a wall and a structural column.
