Cannot create local file
mnguyen2AASC
mnguyen2AASC
I have an issue creating a local file. If it's me to create the file central, I can create the local file but my coworker can not and  opposite, If it's my coworker create the file central, he can create the local file and I can not. Does anyone have any idea how to fix this?
Thank you so much!
Minh Nguyen
SteveKStafford
Make sure your path to the central file is defined in the same way (networking language) as each other. If the path Revit sees to the central file is "different" for both of you then Revit won't regard your central file as the same file and you'll end up in this "loop". That all assumes you're not working via BIM360 hosting.
Steve Stafford
mnguyen2AASC
Thank you Steve!
It work now!
