I am trying to draw a ramp, but it always comes out level, i.e. no slope.
Where should I specify the slope?
Thank you for your help.
Solved by RDAOU. Go to Solution.
@Anonymous Lee
After you start the Ramp command
there you find the slope ...
@Anonymous
Slope of the ramp is a ratio... It rises a height X every L distance traveled
As per standards and regulation, ramps are not only defined by their slope; but also how long do they ravel (considering that one might be on a wheel chair and might not be able to role him/her wheelchair up a 200' ramp...That is what you set in the type properties of that ramp -
If you are doing a pedestrian ramp to ADA standards (That is what your Revit book or better say Eric Wing assumes in their example)...The Max Length cannot exceed 30' 0" and the max slope cannot exceed 1/12
THEREFORE before USER (ex: you) set those values; the user need to
It's simple trigonometry and right triangle formulas
That book or it's author has a Youtube channel I think or website where he has videos of all his chapters...maybe it would help you better if you search for it...
Well or wait for your best friend from Autodesk
@Anonymous
You need to flip it... at the bottom of the ramp there is a smalll tiny icon...click to flip ramp in the other direction!!!
Look this is from the same Author of your book. See at the end how he flips it
