Cannot Change Materials in Revit
adcockcl
Message 1 of 18
adcockcl
revit problem.jpgHello, I just starting using a 2018 version of Revit.  When going to change materials thru the object edit and then edit assembly I cannot.  It seems as thought something is frozen somewhere.  Also, Is there a place I cant edit materials without have to go object edits?   I've never had this problem before, am I suppose to upload material? I can see then in my rendered model.   Thanks, Chris
Replies (17)
Message 2 of 18
Can you open the material dialog from Manage?
Message 3 of 18
-FDC-
Did you install the latest 2018.2 update ?
Message 4 of 18
Viveka_CD
Hi @adcockcl
Thanks for posting on our forum.
Can you confirm if you have the latest updates installed for your Revit version?
See this article HERE and check if any of the solutions mentioned help with your issue.
Looking forward to your reply update.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Message 5 of 18
Sahay_R
To edit materials without editing the object -
Manage>>Material
When you click to edit the Wall materials, do you make it a point to click on the cute little square button with the three dots?
That will take you to the Material Browser.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 6 of 18
Hi Chris, does it happen only when editing in assembly?
Did editing it as an object bring up this problem?
Message 7 of 18
ennujozlagam
@adcockcl hello, i had experienced this with my Revit 2018.2 what i did i go to windows control panel > device manager > display adapter > Name of your graphics card (mine is NVIDIA) >  right click > properties > driver > update driver (it doesn't matter it will update or not) then close > open again your Revit 2018 version and you will be able to change the materials. hope it helps. thanks
Message 8 of 18
Corsten.Au
doesn't seem like revit problem..just a click ...
let us know if its all good now..
Corsten
Building Designer
Message 9 of 18
Viveka_CD
Hi @adcockcl
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Message 10 of 18
adcockcl
All set works now. it most have been a fuke. I will also try v18.2
Message 11 of 18
Viveka_CD
Message 12 of 18
Hey guys,
I've got this issue with Revit 2019 at the moment - I've just gone through and updated the program and my driver as requested above and it still doesn't seem to be working.
Any other ideas??
Message 13 of 18
Mine is doing this now in 2020.....what did you do to fix??
Message 14 of 18
Not sure will it wok it on you guys but I went to the file-> options -> Graphics and turn off the Hardware Acceleration.
It seems like the Video card could be not supported in my case.
After that I just re-open the project and I can finally change the material.
Cheers
Message 15 of 18
ericaG58VB
I'm having the same issue and the hardware acceleration change didn't work for me.  Anyone have any other suggestions?  This is very frustrating....
Message 16 of 18
ericaG58VB
After trying a few things, I ended up uninstalling all Revit Files, and then installing 2022.  I was using 2021.  So far it's working again.  How bizarre, and incredibly frustrating because I didn't need to waste half a day before a deadline.
Message 17 of 18
Pls I need urgent reply to this at the moment....I have tried several ways but I can't still access the material library....have been using this same version 19 for a while now and this is d first time I will be experiencing this
Message 18 of 18
mina_kalami
Community Visitor
Community Visitor
Hi everyone, I have the same issue with Revit 2022 and I followed all the suggestions that has been given in the above but non of them is working. anyone has other suggestion to solve this problem?
