Cancel dwg in .rvt
Cancel dwg in .rvt
Message 1 of 11
Cancel dwg in .rvt
Hello, try to cancel the dwg file but can't do it.
How can I do please?
Not unable the visibility, cancel.
Thank's
Replies (10)
Message 2 of 11
aleksei.tkachenko
Hello
What are you mean with "Cancel"?
You can simply delete dwg if you unpin them in advance.
Message 3 of 11
Delete.
Before unpin and after delete layer?
Message 4 of 11
Sahay_R
Do you want to delete layers?
If you select the DWG, you should see an option to delete layers.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 11
aleksei.tkachenko
Yes, but you can also go to "Manage Links", find your dwg there and remove it from the project.
Message 6 of 11
Why if now reinsert haven't the same link in "manage link"?
When reinsert also say coordinates between dwg and model not coincide.
Thank's
Message 7 of 11
aleksei.tkachenko
Check "Formati CAD" - tab
Message 8 of 11
Here
Message 9 of 11
aleksei.tkachenko
Probably you imported dwg instead of linking it to modell. Imported dwg does not appear in "Manage Links"-tab. You can find them into "Visbility/Graphics"  -window under Imported Categories Tab.
Message 10 of 11
Thank's very much! 😉
Message 11 of 11
aleksei.tkachenko
You're welocme
