I can not lock the extrusions in the depth dimension, just only in the width.
I am sending the family attached.
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von Revit_Whisperer. Gehe zur Lösung
When working with arrays inside a family, it tends to work better if the item being arrayed is a nested family....it's easier to control.
As a side note...arrays make things more sluggish....these bars are under a shelf, so if they aren't really needed I would not model them.
I set their visibility to only show at fine detail.
I attached the file I modified.
