Revit 2017 DWG Export issue
10 ANTWORTEN 10
Nachricht 1 von 11
edwingu
1344 Aufrufe, 10 Antworten
Hii all
Do you have experience with Revit for export to CAD specialy with GRIDS, and out put still with the same quality (line weight, line style, etc). Specialy with using revit link also.
I got problem, with several option Export Setup specialy with Export layer options:
Export all properties BYLAYER, and create new layers for overrides
  • Some model became one color
  • Grids line same look like Revit view(dash, space, dash, space)
  • Sections line same look like Revit view
Export category properties BYLAYER and overrides BYENTITY
  • each model have different layer and color based on setting export CAD from Revit
  • Grids line became continues style
  • Sections line became continues style
Sometimes need to edit again so can same line styles like Revit view.
almost similar "Export category properties BYLAYER and overrides BYENTITY"
  • Create another layer
Question is, how to make CAD files Line weight, line styles, grids etc the quality looks same like Revit when export to CAD?
Cheers,
Edwin Gunawan
Tags (2)
10 ANTWORTEN 10
Nachricht 2 von 11
amorap
als Antwort auf: edwingu
Hi from Spain Edwingu.
have you tried the different existing mapping files that comes with revit (AIA, ISO13567, BS1192...)?
I think that you will need create your own file mapping in order to translate properties from revit objects to DWG entities.
The process isn't simple neither easy.
It is explained in this link, more or less.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Nachricht 3 von 11
edwingu
als Antwort auf: amorap
Yes, I already try... we decide to keep priority for the layer with option "Export all properties BYLAYER, but do not export overrides".
The reason is, easy to change layer ..and the result is same when export to CAD.
I change with AIA, ISO, BS1192, or CP83, the result for the grid lines style...still became continuous.
Cheers,
Edwin Gunawan
Tags (1)
Nachricht 4 von 11
amorap
Have you tried to directly map line type style? (second tab).
You can force the line type assigning one of the ACADISO.lin file.
See this (my revit is in spanish):
Augusto Mora
Tags (1)
Nachricht 5 von 11
edwingu
Yes, seems no changes at all.
Cheers,
Edwin Gunawan
Nachricht 6 von 11
Grid lines are not solid, but you need to change the LTSCALES or other variables controlling the scale.
Nachricht 7 von 11
edwingu
als Antwort auf: ToanDN
Thanks for your tips, but we still keep priority for CAD layer standard with option "Export all properties BYLAYER, but do not export overrides".
I already try this option, still need a lot time change all layer for this option.
Still try another option, for reduce our problem.
Thanks.
Cheers,
Edwin Gunawan
Nachricht 8 von 11
There is absolutely no need to change any layers. The grids are exported with proper linetype if you look at the screenshot I posted.
Nachricht 9 von 11
edwingu
Yes, you are correct.
I also forgot the mention...the project is use REVIT link also, thats why we keep the layers. At Revit link, we also keep layers.
Even for grid, i already try make at main file or use link file.
If you have another option, I'm very grateful.
Cheers,
Edwin Gunawan
Nachricht 10 von 11
ennujozlagam
try this LINK and LINK if can helps. thanks
Nachricht 11 von 11
edwingu
als Antwort auf: ennujozlagam
Thanks for reference guide, actually I use that link reference (for find out my problem).
Still need find this problem...or maybe this is limit from Revit, let see Smiley (zwinkernd)
Cheers,
Edwin Gunawan
