Message 1 of 8
Can you modify a graded region topo after selecting finish surface?
- Mute
- Permalink
- Report
I have a project on a large sloped site. Due to the complexity of the contours, when I graded the site I pressed the finish surface check mark, saved the new surface, and then began to edit but I do not see dashed contour lines where the site has been modified. Do you have to do all of the grade modifications at once? I can't seem to find an answer anywhere else.
(When I have the view phase filter set to Show All, I can see dashed lines where the existing was not modified, and only solid lines where the new contours are.)
Any direction is appreciated! Thank you.
