Can .txt shared parameter files be renamed?
JsphH11
JsphH11
Hi I want to rename the .txt file, I'm kind of afraid by doing so, all the association will be lost.
David_W_Koch
Renaming the file itself will not have any effect.  Revit does not retain knowledge of the source file of a shared parameter.  All that matters is the GUID that is associated with the shared parameter.
David Koch
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
ennujozlagam
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-rename-a-sh...
JsphH11
Thanks yeah is that shared parameters are so "Delicate" with all their Handling rules, one might be afraid of doing so. Thanks I will rename the file as you recommended.
