Revit Rail
Revit Rail
ShifraSpiegel
Message 1 of 8
Revit Rail
ShifraSpiegel
What is the best way to get the bottom railing to follow the angle of the stairs?
Replies (7)
Message 2 of 8
imankassab2015
Select the railing then on the ribbon bar choose pick newhost then choose stair will be taking the shape
If it helps accept my answer
Message 3 of 8
Post the project (RVT) here.
Message 4 of 8
Maybe you don't need a rail there.
Message 5 of 8
ShifraSpiegel
Here is the Revit file
Message 6 of 8
imankassab2015
I solved it for you create ramp beneath those steps as a work around then choose pick new host those stairs
Accept my answer if it helps you
Message 7 of 8
ShifraSpiegel
Amazing. Thank you!
Message 8 of 8
Your railing is simply missing the target. Edit and adjust the sketch linework and/or change the Offset from Path.
