Can't see the View cube?
Have ensured that the View cube box is ticked in Options.
It is ticked but is greyed out, so that I can't view the cube to choose a view.
Also I can only see the Properties or Project browser window not at the same time?
Any idea's?
BIM.Consultant
Open a new project then follow attached image.
FGPerraudin
Hi Damokaa,
Several points:
  1. the 3D viewcube's properties are editable only in 3D views, so be sure to be in a 3D view before following the following steps:
    1. Main Ribbon > View > User Interface, verify that the viewcube is checked.
    2. It always displays as a grey viewcube until you haver it with your mouse...
  2. About the properties, it is very simple. Just click and drag property window the tab header, it will allow you to reorganise the panel as you want them to display (separately, one on each side, or as tabs of the same panel...)
Hope this was of help, do not hesitate if you need more detail!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
I Cannot find view cube after followed the instruction and steps , click and check on box of show  Viewcube still not there. The navigation bar is not there as well. after reinstalled the software the problem persist, when the software able to draw suddenly lost and also lost the ability to function of the workplace. The reason of finding view cube hope to able to draw on work place, at the movement when I click on tool, the cursor on the work place but nothing show up as draw a line or wall or any thing at all. So I cannot nothing do any practise and learning the skill of using the revit. This is two problem or one problem?
Rachel
