Can't modify reveal @ rectangular wall opening.
4 REPLIES 4
shaun_harris
671 Views, 4 Replies
I have been going through this project to modify the returns of the reveal at door and window openings.  There are a few places that the wall is thicker than the or door host so we are using a rectangular wall opening.  Now we're running into the problem of getting the reveal to return back at the end of the wall where the wall opening cuts out the wall.  Is there any way around this?
Tags (1)
4 REPLIES 4
in reply to: shaun_harris
Is this what you are talking about -- the reveal corner return?
shaun_harris
in reply to: barthbradley
That's exactly what I'm looking for.  For some reason most of the ends of the reveal I can modify and return around the end of the walls but there are certain instances where we are cutting the walls with a wall opening and it won't allow those ends to modify and turn the corner.
Sometimes they require finessing. In those cases where you don't see 'em, do you have 2 blue dots? Drag the end dot beyond the corner.  Do you see what is show is shown in screeeshot?
shaun_harris
Not a perfect solution but I think we can work with this.   I just pulled the end slightly further out from the end of the wall and then it allowed me to modify the return. It will give us the look we need it to anyway.  Much appreciated for the help.rectangular wall opening and reveal2.png
Forma Design Contest
Technology Administrators
