Can't load Baluster into railing
Message 1 of 12
I created a baluster panel (1.jpg) of 6'x3' in the Baluster panel.rft template: but i can not load it in to a railing system in a project. I get this error (2.jpg) when i try it. Then i tired to simplify the design like the in the 3.jpg and it works (4.jpg) can anyone tell me what i'm doing wrong?
Replies (11)
Message 2 of 12
Avaris.
I would recommend creating it using the baluster-panel template. I think the sides are not referenced to anything.
PS: Try to avoid having balusters base/top referenced to a railing, always choose host. You'll thank me later if you accidentally delete a railing where you have a baluster referenced to.
Message 3 of 12
I Actually did it in in the Baluster panel template, sorry for mentioning it as Baluster Template
Message 4 of 12
Avaris.
You do have a lot of reference lines in your family, but I see no reference from the edge of your extrusion to the original reference planes of the family. I would remove all the additional reference lines and make sure the edges of your extrusion are constraint to the front/back top/bottom reference planes (you can use offset).
Message 5 of 12
Thank you for your reply but its not working, i deleted all the all the references, and constrained Left, right and bottom to their respective edges and one face to left/right and the other to a value, still i get the same error.
Message 6 of 12
Message 7 of 12
@Anonymous: Curious about what the fix is?
Revit has a limit. 1/32".  Any sketch line, or model line, or any distance for that matter, is problematic when drawn at less than 1/32". I found 2 that were less that 1/32" in your sketch.  Revit is still not quite liking the sketch in the Project, but she's tolerating it and throwing an error to let you know about.
Message 8 of 12
I'm very much happy to see that it works and thank you very much @barthbradley, but i'm using Revit 2017. I removed the two smallest lines  but still i'm getting the same errors. It will be very help full if you upload the project file with the loaded railing
Message 9 of 12
Message 10 of 12
Thank you very much  barthbradley, you saved my day, when i looked in to the file it seems that i too removed the same two small lines but i think this tolerating thing is only happening in 2018 and above, thanks anyway
Message 11 of 12
@Anonymous wrote:
... but i think this tolerating thing is only happening in 2018 and above
No, I'm just better the second time around. Smiley Wink
Message 12 of 12
Good day
I'm new to Revit, I would like some help with Loading my railing family options. I don't have much to choose from so I tried editing the one I do have, but it still does not give me different balusters and hand rails to choose from...
Regards
