Can't get Stairs sitting flush with flooring
3 REPLIES 3
1436 Views, 3 Replies
Hi guys, i have put a spiral staircase in my store, but i cant seem to get the top step, to sit flush with the floor, I have tried to change the desired stairs height, but that doesnt seem to make any difference? Thanks in advance.
3 REPLIES 3
RDAOU
Hey @Anonymous
  1. Select Stair >> go to Modify Tab and Click Edit stair
  2. Select the flight (steps)
  3. In the properties palette >> Uncheck "End With Riser"
You will get a warning that the stair does not reach the top/destination floor...You will need to readjust number of risers and travel height
in reply to: RDAOU
Thank you! 🙂
RDAOU
@Anonymous
Any time welcomed 🙂
Forma Design Contest
Technology Administrators
