I have a generic model family that I want to edit it. it is made for the facade finish.
However, I can't reach the family name in model families, also no icon shows edit family when I select it.
Hi @sorour4cad
Thanks a lot for posting your question to the forums! The family you are trying to edit looks like a system family.
System families are predefined in Revit and saved in templates and projects, not loaded into templates and projects from external files. You cannot create, copy, modify, or delete system families, but you can duplicate (copy) and modify the types within system families to create your own custom system family types. You can delete all but one system family type in a system family, because you need at least one type per family to create new system family types.
Although you cannot load system families into templates and projects, you can copy and paste or transfer system family types between projects and templates. You can copy and paste any number of individual types, or use a tool to transfer all types in the system families that you specify.
I hope this helps.
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
It is a direct shape element and uneditable in Revit unless you can create parts from it and edit parts. This one looks too complex to be created parts from though.
