exporting floorplan to IFC exluding shaft shaft
3 ANTWORTEN 3
Nachricht 1 von 4
helge_wichstadVLVMU
276 Aufrufe, 3 Antworten
I`m trying to export 5.th floor to IFC, but the shaft`s are include down to 1.st floor. And I get problems with import to a external software. I have tryed to remove it bye VG Shaft, and then just export all in view. but will not work.
Any suggestion ?
3 ANTWORTEN 3
Nachricht 2 von 4
Simon_Weel
als Antwort auf: helge_wichstadVLVMU
What's the problem? Shaft too high? Then adjust the top / bottom constraint.
Nachricht 3 von 4
Create multiple shafts, one for each level.
Nachricht 4 von 4
Hi @helge_wichstadVLVMU
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
