Can't divide surface on imported SAT model
0 REPLIES 0
Message 1 of 1
Yazeed_Ibrahim
94 Views, 0 Replies
Hello, I have spent a lot of time trying to divide the faces of this 3D model that I created on Fusion.
I tried many ways like importing it into a conceptual mass file or using the Link CAD option inside the in-place mass edit menu. I also tried to use a different mass without any thickness and didn't work, I believe the biggest issue is that I can't select all the faces at once so that I can reveal the divide surface options.
I am trying to divide the mass to make this special pipe facade that is used in the Ithra building by Zaha Hadid like this:
I uploaded the SAT file and if there's a better way to do it other than dividing the mass I'll be thankful.
Tags (3)
0 REPLIES 0
Forma Design Contest
Technology Administrators
