Hello, I have spent a lot of time trying to divide the faces of this 3D model that I created on Fusion.
![Yazeed_Ibrahim_0-1713354595995.png Yazeed_Ibrahim_0-1713354595995.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1350963i9AC2DD684ED3EA02/image-size/medium?v=v2&px=400)
I tried many ways like importing it into a conceptual mass file or using the Link CAD option inside the in-place mass edit menu. I also tried to use a different mass without any thickness and didn't work, I believe the biggest issue is that I can't select all the faces at once so that I can reveal the divide surface options.
I am trying to divide the mass to make this special pipe facade that is used in the Ithra building by Zaha Hadid like this:
![Yazeed_Ibrahim_5-1713355188559.png Yazeed_Ibrahim_5-1713355188559.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1350971i73E8F7AF52A57D6D/image-size/medium?v=v2&px=400)
![Yazeed_Ibrahim_4-1713355125366.png Yazeed_Ibrahim_4-1713355125366.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1350969i039067D8F2C70AEE/image-size/medium?v=v2&px=400)
I uploaded the SAT file and if there's a better way to do it other than dividing the mass I'll be thankful.
