Can't Cut Geometry With Void
dm0144
dm0144
Hello everyone
When I try to cut a floor element with a void modeled within a door family, I cget an error measge, saying that the wall can not be cut with that particular door instance, thus the door gets deleted.
Any help?
kadmonkee
do you have overlapping walls? the image looks like there are 2 different walls and a door
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
dm0144
@kadmonkee check revit model please.
kadmonkee
unfortunately I am not running the latest version to open your file
thank you
RDAOU
@dm0144
Do the following
  1. Edit door family
  2. Delete the Opening Cut element and replace with a Void extrusion
  3. Cut wall with the new void extrusion
  4. Cut wall with the void from the floor box
  5. Load into Project
    • Use Cut Geometry to cut floor with the door
Alternatively...
  • Model the Floor Box Void as a Nested Shared Generic Model
  • When cutting in the project, use Tab to select just the nested shared generic void extrusion
See GIF below...
dm0144
@RDAOU Thanks!
