Can't change dimension.
For example if  I it try to change this value "2126" it give me this error.
One more problem is that the dimension isn't changing to one that I wrote,for some reason if a type 800 it changes to 1387.4
aRcHiTeCt.JM
.... it is probably because the dimension has been constrained
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Assign that dimension to a parameter, then change the value of the parameter.
Corsten.Au
HI
Check on other views..
Front Elevation
Back Elevation
and you may find that distance already locked and constraint..
Best luck.
Corsten
Building Designer
UNPIN THE CENTERLINE.
Did you even try unpinning the Centerline?
The pin is the only thing preventing you from changing that dimension.  Or was the question how to add a label to a dimension?
...have you tried changing the Dimension Style Font?
