Can't attach a landing to two stairs
8 REPLIES 8
Message 1 of 9
advandes
3091 Views, 8 Replies
Revit 2019 - File Attached
I was hoping someone with more experience could help me out with this issue. I can't get these two stairs to be joined with a landing and also have the railings joined properly too. When I use the landing routine, the program will not select the second set of stairs. Thanks for any help!!!
AAG
Advance Design
8 REPLIES 8
Message 2 of 9
in reply to: advandes
Why not add it to one of the stairs?
Message 3 of 9
Two runs in one stair or two stairs? If two stairs then just add a landing by sketch to one of the stairs. Better yest built them as runs within one stair then you can create landing automatically.
Message 4 of 9
A little tricky.  I converted to Stairs to Sketches. Put Landing in Stairs.  Still looks quirky.
Message 5 of 9
RDAOU
Screencast
Message 6 of 9
in reply to: RDAOU
How does yours come out when you use a wider landing like the OP's?
...Never mind. My bad. The OP's project doesn't have any landing info.  Don't know where my landing dimensions came from.  I was fighting to make those corner support returns for nothing.
...nice job! I'm impressed.  Elegant solution.
Message 7 of 9
Here is how I fixed it.  It may or may not be the same as others' approaches.
https://knowledge.autodesk.com/community/screencast/ec7005ce-13cd-4473-9dd5-72205546e931
Message 8 of 9
advandes
in reply to: ToanDN
Nicely Done!!! Thank you!
AAG
Advance Design
Message 9 of 9
advandes
in reply to: barthbradley
Nicely done as well! Thanks
AAG
Advance Design
