Revit 2019 - File Attached
I was hoping someone with more experience could help me out with this issue. I can't get these two stairs to be joined with a landing and also have the railings joined properly too. When I use the landing routine, the program will not select the second set of stairs. Thanks for any help!!!
Solved by ToanDN. Go to Solution.
Solved by RDAOU. Go to Solution.
A little tricky. I converted to Stairs to Sketches. Put Landing in Stairs. Still looks quirky.
Screencast
How does yours come out when you use a wider landing like the OP's?
...Never mind. My bad. The OP's project doesn't have any landing info. Don't know where my landing dimensions came from. I was fighting to make those corner support returns for nothing.
...nice job! I'm impressed. Elegant solution.
Here is how I fixed it. It may or may not be the same as others' approaches.
https://knowledge.autodesk.com/community/screencast/ec7005ce-13cd-4473-9dd5-72205546e931
