09:27 AM
I was able to do it up along the left side as you can see, but right now I'm working on the bottom left side. At the left side I was able to use the aligned dimension tool and pick points from center to center of the posts and come up with the distance. But when I try that with the bottom left corner between posts it just gives me the side line of post and it doesn't give a point. I'm also concerned if i do that and try to change the dimension it won't follow the circle.
