Nachricht 1 von 2
Nicht anwendbar
05-05-2016
09:27 AM
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
I was able to do it up along the left side as you can see, but right now I'm working on the bottom left side. At the left side I was able to use the aligned dimension tool and pick points from center to center of the posts and come up with the distance. But when I try that with the bottom left corner between posts it just gives me the side line of post and it doesn't give a point. I'm also concerned if i do that and try to change the dimension it won't follow the circle.
Gelöst! Gehe zur Lösung
