Can not load column
Can not load column
Can not load column
Hi community. I download a column from Revitcity. But when i load the column to my file it pop up something like attached image. How can i do? thank you very much.column.jpg
L.Maas
The error message explains it. Revit is expecting a structural column. Apparently what you are loading is not a structual column.
Probably you are loading an 'architectural' column. Check the family to see if you have a column belongin to the proper category
Louis
Please mention Revit version, especially when uploading Revit files.
I put the downloaded column in both : Columns and Structural columns. Both are error. What happen?
Open the column family directly and see which category it belongs to.
Thank you! i got it
