How do you make a Default Elevation/Reference Level an instance parameter?
I'm trying create an instance parameter for a railing support post so I can apply a grip that will allow me to adjust the default height of the support family. Is this possible? Thanks!
RDAOU
Short answer: Yes it is possible to add grips to control Height/Width parameters in a family after inserting into the project
it's not clear in which context you want to use such a balustrade so I am not sure how to elaborate more with the answer. Im also not sure how such grips would function with a rail which has 100 balusters! on a nonregular/sloped/curved path!!! I would suggest that the top rail goes with grips and balusters be adaptive...
If you provide more details, handsketch or anything...maybe one can give you a screencast; otherwise, if you are not looking for something specific, there are lots of Adaptive Railing tutorial as well as turtorials on how to add grips to families. I know @Alfredo_Medina has something about Adaptive Railing on his Youtube channel you could check out HERE there are also some examples about Adaptive components and parametric families (with and without grips) on the Autodesk Knowledge Netwrok which are usefule .
Thank you for you quick responce! I'm attaching a picture of the parameter I am trying to carry over to another family.
L.Maas
Some things just can not be controlled by parameters. In most cases it is logical. In other case it is not so obvious but it is just not implemented (yet).
Louis
Please mention Revit version, especially when uploading Revit files.
