Hi there,
I am following a video to draw the stairs. But when I click Component - Model In-place. The option of 'stairs' in the family category and parameters is missing. How can I find it out or create a category of stairs?
Thank you.
Solved by Avaris.. Go to Solution.
Hi Toan,
Thanks for your reply.
I'm following a video to draw the stair, which has some shelves behind it. Not sure how to draw the same one by using the stair tool. I've attached the stair section and 3D view.
Could you please help me with this issue, or how can I draw the same one?
Many thanks.
The stair in place is added quite recently, which version are you using?
You can also use a generic model in order to draw this stair. It will not change your workflow.
I'm using 2016 version, this is probably the reason why I couldn't find it.
Finished it by using a generic model!
Many thanks!
