can model-inplace sweep with void
BIM_Dreamer
Message 1 of 8
BIM_Dreamer
it is possible that a model in-place sweep can cut with void like wall reveal? or any suggestions? thanks
Replies (7)
Message 2 of 8
hmunsell
Why not use the Wall: Reveal tool? what are you trying to do?
Howard Munsell
Message 3 of 8
Create In-Place Void and then before you close out of In-Place Modeling Session, use the Cut Geometry tool to cut the System Family Geometry with the Void.
Note: not everything will "cut".  For instance, you can't cut Stairs or Loadable Families with In-Place Voids.
Message 4 of 8
BIM_Dreamer
@hmunselli know what you mean. i had already mention that is a model in-place sweep profile and cannot use wall to do this. thanks
Message 5 of 8
BIM_Dreamer
@barthbradley  it is a model in-place sweep profile and cannot cut as you've mentioned or can you please show it to me how to do that. thanks
Message 6 of 8
Edit that model in place and add the void, then use cut geometry and finish.
Message 7 of 8
hmunsell
so you have a element that was modeled in place, and you want to place a void on it to represent something similar to a Reveal? unfortunately Reveals can only be placed on walls. edit your Model in place and add the needed voids/cuts.
https://autode.sk/2R6FGye
in this example i made the in-place family a wall, but it can be anything...
Howard Munsell
Message 8 of 8
BIM_Dreamer
how.. show me,  it's a sweep model in-place. thanks
