Title is confusing. Really all I want to know is if it is possible to use the cut profile command the part circled in red.
I know there are other workaround for this, just wondering if this is possible and I'm just not drawing the cut profile lines correctly. Thanks
Solved by barthbradley. Go to Solution.
I can't tell what elements those are. System Families? Post the file here.
The Cut Profile tool can reshape walls, floors, roofs, stairs that are cut in a view. The changes made to elements using the Cut Profile tool are view-specific for 2D views only .
Thanks for the responses. Let's try this example instead. Is it possible to use the cut profile to eliminate the bottom half of this wall in this view?
I have no issues applying a cut profile. Not sure what kind of cut profile you are after, but maybe you are missing the two Options you have available: Face or Boundary between faces.
I have those two options, just not sure how to apply them to eliminate piece of something that has already been split in two parts by other geometry.
Could you do me a favor and screenshot how you drew the cut profile to eliminate all of the wall below the floor?
Thank you very much
Like I said, I don't know what cut profile you want, but here's an example:
Note: wall color change to red for clarity.
@jblanchetteRT93G wrote:The part of the wall that is circled
I don't know what I'm supposed to take away from this post. Are you wanting the Cut Profile to HIDE the entirety of wall below the floor? If so, that doesn't make any sense to me. Maybe better to describe the actual construction/condition for me.
Thanks for the response. All I want to know is if it is possible to do this with the "Cut Profile" command because there are times when doing sections/details that it would be the most convenient to do it like this.
Obviously eliminating an entire masonry wall below a floor is not a real world example. I'm using that as an example because my question is really about the mechanics the command in question (Cut Profile), and whether or not it is possible to use this command to completely eliminate one part of an element that has been split in two pieces by another piece of geometry.
I don't know what else to say other than what I have said multiple times in this thread haha.
I'll take that as a "no" on the question of using Cut Profile, but I do like the solution of using "exclude" on the piece after "create parts".
Thank you
Ok. Could you share a screenshot of how you draw the cut profile to do so?
Not to beat a dead horse, but here is an example I ran into just now where I, in this section view, REALLY wanted to use Cut Profile to hide the exterior finishes of this roof truss that lie below the adjoining roof:
I can't break the roof assembly into parts so I'm going to have to use a masking region. Using masking regions can be kind of a pain to make them look clean, so this is why I asked my original question 🙂
