I cannot seem to edit the Type Image parameter for a curtain panel family.
I can edit the Image parameter but not the Type Image one. Any insight on the matter would be appreciated.
Solved by vitorbortoncello. Go to Solution.
You can add Type Image to Custom panel families. Or you can use a basic wall type for curtain panels and assign type image to the wall type.
You can add a new image type parameter to Curtain Panel category.
So that is a negative for the normal curtain panels?
Thank you. Good to know. We will probably use the instance Image parameter sadly.
A Curtain Panel CAN have an Image Type Parameter.
