Can a Curtain Panel have a Type Image?
9 REPLIES 9
Message 1 of 10
curtisridenour
410 Views, 9 Replies
curtisridenour
I cannot seem to edit the Type Image parameter for a curtain panel family.
I can edit the Image parameter but not the Type Image one. Any insight on the matter would be appreciated.
9 REPLIES 9
Message 2 of 10
in reply to: curtisridenour
You can add Type Image to Custom panel families. Or you can use a basic wall type for curtain panels and assign type image to the wall type.
You can add a new image type parameter to Curtain Panel category.
Message 3 of 10
curtisridenour
So that is a negative for the normal curtain panels?
Message 4 of 10
vitorbortoncello
No, a Curtain Panel in Revit cannot have a Type Image parameter. However, you can use the URL parameter to link to an external image if needed
Message 5 of 10
curtisridenour
Thank you. Good to know. We will probably use the instance Image parameter sadly.
Message 6 of 10
A Curtain Panel CAN have an Image Type Parameter.
Message 7 of 10
curtisridenour
Yes a project/shared parameter would allow for that. But the OOTB "Type Image" parameter I don't think can be used.
Message 8 of 10
Message 9 of 10
vitorbortoncello
This solution will only work in Revit Full, not in Revit LT
Message 10 of 10
curtisridenour
I was specifically looking to use the OOTB parameter Type Image. We already use this parameter for most of our schedules. I was very confused why I could not use the same parameter for a Curtain Panel Schedule. I am sure Autodesk has their reason but it seemed really odd that I could not. I was hoping it was not just User Error on my part. I was seeking confirmation of my assumption. Vito provided that confirmation.
