Automate sheet issue dates
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
cbt990
2727 Aufrufe, 5 Antworten
This is possibly related to the way my colleague set up the title block family. i would like to be able to change the issue date ONCE and have it propagate to all sheets, rather than adjusting for every sheet in the project. Is there a way to modify the parameters of the title block family to do this?
Thank you
Revit is amazing
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: cbt990
Edit the titleblock family and change label from Sheet Issue Date to Project Issue Date.
Nachricht 3 von 6
You can use a Sheet List (Schedule) to manage Sheet Properties.
Nachricht 4 von 6
ahmadfiroozi000
You can edit the sheet and create a label according picture bellow
Nachricht 5 von 6
cbt990
als Antwort auf: barthbradley
I think this is the best answer because it enables me to quickly change/verify all issue dates at-a-glance.
Is there a way to set up a schedule for issuances? Currently, I update my issuances by updating the title block family. Then, I would use my sheet list to change all the issue dates on the sheets. but I would still prefer to only enter the issue date in one location and have it propagate to all sheets.
Revit is amazing
Nachricht 6 von 6
KurtYU9TN
als Antwort auf: ToanDN
@ToanDN Is there a way to add additional project issue dates? for example listing the different deliverables like S.D., D.D, Permit Set, and IFC Set? I want to keep a Distribution Log and have it as a type parameter, but when I add the parameter to the projects to link the information I can only add a sheet parameter as an instance. Any help would be much appreciated.
