I want my callout tag to show the name of the callout view. But it seems like it is not possible to choose this option. Is it true?
That means we would have to manually keep track that the View name corresponds to Detail number.
If you want the view name to be available as a label…
see attached file.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
the "View Name" is just a sample text for you to place the Label how you want in the family. It will pull the name of the view out when in the Project and display the data accordingly.,
Sorry, the "Sample text" is not a problem nor my focus.
Just saying that my label automatically changes from "View name" to "Detail number" when i change the family category.
Hence when I upload to the project it shows me "Detail number" - not good.
So it is a mystery for me to see your family working, but I am trying to reproduce it myself and no luck.
can you take my family, save it as a new family and modify it accordingly?
sorry....still trying to figure out the mystery. I cannot reproduce my steps to make the family again. However, the original family I made for you shows the following:
Selecting View Name Label and going into Edit Label window shows Label Parameter is View Name as well as Sample Value
When I use it in a Project, it functions properly...
Yes I agree, the original family uploaded by you still works.
But if I try to modify it and change family category forth and back - then parameter in the label also changes automatically.
I did the procedure, but when I load the new head, appears moved (not centered) !!! any tip?
Stumbled across this post while trying to create a callout with View Name. Figured out the correct sequence to copy View Name label to a Callout Head family:
This way it retains the original label with View Name in the clipboard but doesn't give an error message about trying to copy and paste labels across families of different categories.
Hello.
Thank you for his solution. Even though you have written about this a long time ago, it was very useful for me today :).
Best regards,
Roxana
Work arounds are fine, but we need Autodesk to allow more label categories in the system family used for view references! It's just not enough that we can only use the 2 pre set catogories 😞
