Hello, I'm new to Revit, I have 2 problems. The first is the intersection of the column and wall plasters, the plasters surround the column, I do not want this to happen, I want the reinforced concrete wall to intersect with the wall, how can I do it?
My second problem is that when I cut sections in Revit, I sometimes want to show some lines in the background as dashed lines. I couldn't find a way. I would be glad if you could help me.
The structural column is already the same. The plaster materials are the same and this is what happens when the order of joining is changed.
Regarding #2, increase the far clip distance to include the beyond roof and use Silhouettes.
@jhdrvn65 wrote:The structural column is already the same. The plaster materials are the same and this is what happens when the order of joining is changed.
I'm not following. I can see by the behavior that you are using an Architectural Column. Show me a screenshot of the unjoined condition.
How about setting further view clip and use match line tool.
OR set roof cut line to be much bolder than projection line, like 5 vs 1.
