Calculate excavation and backfilling
amr.atiya
amr.atiya
Hello All,
I have a building (Underground Tunnel) Modeled in Revit as floors and walls. I have the survey from the site excavation imported as a toposurface. The toposurface in some places was not excavated enough and in some places excavated more. Is there a way to know the quantities of the needed excavation and back filing from the Revit?
Thanks in Advance it will help me a lot.
Do you have a Toposurface, Graded Region Copies and Phases?
Calculating/Scheduling excavation and backfill requires a "source" Toposurface followed by a  Graded Region Copy of that "source" Toposurface placed in a subsequent Phase of construction.
 This is not an easy process to explain in a short post, but there are plenty of tutorials available on line to read and watch.
Start here:
toposurface | Learning Revit Online
About Reporting Cut and Fill Volumes on a Site | Revit Products 2016 | Autodesk Knowledge Network
