is there a possibility of an easy creation of a wall around a slanted column? I tried "wall by face" (firstly making a generic model in the exact shape as the column) method, but the created wall cannot be edited - the ends can't be dragged, it doesn't join with other walls, etc.
Below you can see the generic model and the created wall (only half of the round column has to be insulated).
Any form of help will be appreciated ![]()
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
I can think of at least 2-3 other alternatives but the above are the easy basic ones
Hi @RDAOU
Thank you for the quick response!
Unfortunately none of the methods mentioned above matches my needs
But in some cases those tricks can do the job, so I'm checking it as a solution.
I've already realised that vertical room boundaries are determined by column base outline - even though I manage somehow to model the insulation in 3D properly , it won't be listed in my "room finishes" schedule which is created with Dynamo script (it takes wall finishes basing on the 3D solid created from the shape of the room).
Anyway, thank you for your time, cheers!
