Building pad 0,0002 m over the cut topography, why?
tareqathamneh6QW84
Message 1 of 14
tareqathamneh6QW84
it is adding some unnecessary calculation to my quantities schedule..
Thansk!
Replies (13)
Message 2 of 14
This is about 0.0078740157 Inches (1/127")?
Message 3 of 14
Maybe the soil is wet. Let it dry out.  😉
Message 4 of 14
tareqathamneh6QW84
@barthbradley 😂 dude..
this is messing my schedule ..
Message 5 of 14
I don't understand the issue.  You say the Building Pad is slightly higher than the top of the Toposurface. So what?  Also, how does this mess with a Schedule? A Schedule of what? Topography?  The Pad and the Topo are two separate Categories.
Message 6 of 14
Maybe your Building Pad has a Height Offset from Level?
Message 7 of 14
tareqathamneh6QW84
@barthbradley The pad is at the correct level, which is aready dug, but the toposurface is starting a tiny bit under it, which adds 0,02 m3 to my schedule instead of being a clean zero..
Message 8 of 14
@tareqathamneh6QW84: I don't want to play guessing game anymore.  Post your file here and I'll tell you exactly what's going on and what to do about it.
Message 9 of 14
just a thought here...
Is your Building Pad made up of layers?
Message 10 of 14
tareqathamneh6QW84
@barthbradley here is the file, thanks, I appreciate it.
there are no layers in the pad..
Message 11 of 14
Set Height Offset from Level to 0.
Message 12 of 14
Solution is posted in Message #6.
Set the Pad's Height Offset from Level to ZERO.
Message 13 of 14
tareqathamneh6QW84
I did, still there.
Message 14 of 14
@tareqathamneh6QW84 wrote:
I did, still there.
The topo itself already has 0.203 m3 Cut without the pad.  Did you create it using Graded Region?
