Building missing in west elevation
Message 1 of 8
For some reasons, I cannot see my building in the west elevation view. I can see the building in all the other elevation views. I have already checked the Visibility and 'reveal hidden elements' but still cannot see anything. I have also tried to print the current window but it is still empty. I am new to Revit so any advice would be helpful, thank you.
Replies (7)
Message 2 of 8
Check the Phasing.
...Are you sure the cut plane is positioned in front of the Building.  Check it in Plan View. Maybe you moved it by accident.
... set Far Clip to None.
Message 3 of 8
syman2000
When you print by current window, did you check and make sure your views are cropped? Often if you uncrop the view, it will show object away from your elevation and give you blank page.
Message 4 of 8
Message 5 of 8
Message 6 of 8
Nice @ToanDN. I think you are messing with us now.
Try this one:
Too Twilight Zoney??? I like it personally.
Whatever works.
Cheers.
Message 7 of 8
Hi, I am not sure if what I did was right but I saw a straight line in the plan view and just moved it from the right hand side to the left hand side. Somehow that fixed the problem, I think that is called the cut plane although I am not sure. Thank you very much for your suggestion as I would not have checked the plane view otherwise.
Message 8 of 8
Hi, I don't think that was the problem, it was because I moved the cut plane. The problem has been resolved now, thank you for your suggestion.
