Bug with View Range issue for showing Detail Level Fine
Ajay_J_S
Ajay_J_S
Hi, I have an issue with the view range showing Detail Level: Fine for Walls. This seems to be a Bug or something that I came across it. I have drawn few walls of height 2000mm & the view range: Cut Plane is set to 1500mm the wall layers are visible clearly. When the wall height goes below 2000mm i.e. 1900mm, 1800mm the wall layers are not visible. When we draw a wall of height 1000mm & view range: Cut Plane is set to 600mm still the wall layers are not visible in Detail Level: Fine. I have attached a video clip below for better understanding.
Can someone help me with this? Is this a bug or does Revit works like this?
@revit @revit
SteveKStafford
If a wall is less than six feet (or 2000mm, no not exactly equal to six feet) it will NOT use the Cut line weight, it will only show using the Projection line weight. You can "force" Revit to show it as Cut by setting the Top Constraint to the level above and using a negative Top Offset value to drop it back down to it's intended overall height. A bit obtuse but it works! You can also set the Top Constraint to the same level as the Base Constraint and then use a positive value for your Top Offset value.
Keep in mind that if the height of the low wall is still lower than the cut plane of the view's view range setting it will not show using the cut lineweight, only the projection lineweight. The distinction of this post is for walls that are taller than the cut plane but not quite tall enough (six feet)
Steve Stafford
Ajay_J_S
Hi thanks for the replay. I understand about the wall height below cut plane and the projection line weight is considered. But what about the walls present with height more than cut plane weight still doesn't shows until the wall height reaches 2000mm it is not a good way to show the wall layers. I understand your workaround solution. Thanks for that. But still, I would prefer Autodesk to focus on bugs or issues like this & solve these issues which would make Revit much better. Thankyou anyways for your solution
SteveKStafford
It's not a bug from their perspective, it works the way the programmed it, on purpose. The architects that designed Revit originally considered short walls to be different enough from full height or load bearing walls to make them look different automatically.
You can submit a "Idea" to the Revit Ideas forum asking to change the behavior.
For now you can use one of the work-around(s) I mentioned and/or you can use a plan region to shift the cut plane down to intersect with the wall differently where the short wall(s) occur.
Steve Stafford
Ajay_J_S
Thankyou for your Reply
