I am having a problem where the EQ function on a dimension string is adjusting the end element rather than the center element. For example, I would like to place a component centered between two lines 10' apart by just hitting the "EQ" on a dimension string. Typically, the result is a spacing of 5';5'. However, if I start with a spacing of 4';6', I end up with one line moving to make a spacing of 4',4'. When I try to lock the lines, I get an error.... When I use walls instead of lines it works just fine. I am using Revit LT 2016.
