Break lines not complete
millerew17
Message 1 of 9
millerew17
I am using Revit LT 2013 and my Break Line only breaks half of a simple detail line not both. I flipped it around a few times and the unbroken line segment stays with it. It works totally correct with my walls. What's my fix?
Thanks!
Replies (8)
Message 2 of 9
Can you show a screenshot of it?
Message 3 of 9
millerew17
How's this?
Message 4 of 9
That looks normal.  It masks the line exactly how it does the wall.  I am not sure I understand your problem.  Do you want to remove the segment marked below too?
Message 5 of 9
millerew17
Yes, that is what I'm wanting to do.
Message 6 of 9
That is how it should work because that segment is within the unmasked side.
Anyhow, you could edit the family and add a mask on the other side but it might not work well when you use it on something like a wall, a floor, or a hatch pattern. Maybe add a visibility checkbox to turn it on only when you need it.
To be honest I would just leave it as is.
Message 7 of 9
chrisplyler
I'm not entirely sure I'm understanding correctly...
Is that break line right on the edge of a wall/slab/whatever? Why do you need to break something that stops right there anyway? Move your break line up a bit, and widen it to cover the full width of the wall/slab/whatever. Then it will look properly broken (breaked?).
Message 8 of 9
millerew17
Chris,
You nailed it! I moved it up and widened it out and got a better understanding of how this works. I stopped short and added detail lines to make up the difference on each side. Reviit is great but so much to learn!
Message 9 of 9
chrisplyler
Glad to have helped.
Yes, Revit requires a big learning curve. Am completely self taught myself, having watched untold hours of youtube videos and spent an equal amount of time on this forum. It isn't just "drawing."
