Chamfer on window opening
arcsurvey
Message 1 of 9
arcsurvey
Work in progress: How do I create a chamfered reveal where the red lines are? I am using Revit LT 2017 so I do not have an in place void tool. I need to create the chamfer in the family. When I have tried a void sweep it will not allow a void in the host wall of the opening.
Any ideas to help me out?
Thanks.
Replies (8)
Message 2 of 9
Remove the opening cut and use void(s) to cut the wall.
Message 3 of 9
arcsurvey
Thanks. I will try that tomorrow.
Get Outlook for Android
Message 4 of 9
arcsurvey
Hi, I've cut the holes through the wall using a void extrusion which worked for the main void. Then I tried to do the chamfer as a void sweep. I get this error as soon as the two voids touch / overlap. I also tried doing it as two void sweeps and I get the same error. Can anyone tell me what I'm doing wrong?
Thanks.
Message 5 of 9
loboarch
Just looking at the geometry you might be getting the error because the void is "self intersecting" at the point. I am not sure without seeing the family for myself, but tight corners like that sometimes cause the self intersecting situation.
Could you maybe make the chamfer shape as a void blend instead of a sweep? If there is a self intersecting problem with the sweep the blend would avoid that issue.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 9
arcsurvey
Thanks Jeff,
I tried as you suggested. The void blend works for the chamfer until you try and join / align the void blend and void extrusion to make the void complete through the wall.
As soon as they touch, I get the message shown below. When separated both voids form correctly.
Thanks, Richard.
Message 7 of 9
Create a single void sweep blend with 3 profiles.
Message 8 of 9
arcsurvey
Thanks. I'm not sure how to do this. I only have the option to do a single swept blend with 2 profiles, not three, unless I misunderstood.
However, you got me thinking. I tried a swept blend for the chamfer and a sweep for the main opening and this combination did work without an issue.
Thanks for your help.
Message 9 of 9
@arcsurvey
You are correct.  I was thinking multiple profiles along the sweep path similar to what you could do with a conceptual mass but it wasn't the case.  Glad you figured it out.
