Border Tile : Partial leaves overhang
parleyburnett
Message 1 of 28
parleyburnett
I have a very simple case:
a surface (not rectangular  is divided into a grid pattern.  I have an adaptive curtain panel assigned to fill this pattern.
why is there a 2" overhang of my curtain panel when my Border Tile setting is set to partial?  It trims perfectly on some but not on others. (See attached pic)
Replies (27)
Message 21 of 28
enji.sorial
But this solution only solves the geometry, but not the quantities. Is there a solution to the quantity problem? Kindly find the link to the file: https://wetransfer.com/downloads/8d82d29de4da47f3214465703e1cef3920190917050849/5d25fd496dc742cee0b3...
I also have another problem; that I have 3 pattern-based families with nested families (2 nested families each), so it doubles the quantity of the nested families despite the border.
For example: no. of Hexaplates  - Pattern-based 1= 288 whilst no. of hexaplates (Generic) = 576.
Message 22 of 28
martijn_pater
Another idea is to make an in place geometry (solid) as SEO (Solid Element Operations) element and subtract (join/cut) this solid from your surfaced mass. Then assign this solid to a seperate subcategory (named SEO ie.) and turn that off in views/view templates.
Possibly then it would result in the correct geometry as well as volume? I haven't tested that yet, but this should then also work for curtain panels/mullions and or glazed roofing.
Message 23 of 28
enji.sorial
Could you give an example on how to do it, I can't quite understand.
Message 24 of 28
martijn_pater
See attached example / image.
Message 25 of 28
davidamar
Observer
Observer
I agree. This issue has been going for way to long. Everytime I have this issue I spend time searching online for an answer hoping they have resolved it! Still nothing. Have they resolved in in 2020 version? If so I will use that instead of 2019.
Message 26 of 28
atis.sed
Revit 2021 and this still is an issue... But now we have schedules with alternating colors yay.............
Message 27 of 28
lestervidalgutierrez
Comming from Revit 2024 and nothing yet. Still the same problem from over more than 12 years
Message 28 of 28
jack_coleMVS8P
Insane they still haven't fixed this...
