REVIT 2016 callout by sketch
I am creating a callout by sketch.
When I use a callout shape that is not rectangular and place the callout on a sheet, part of the callout view content disappear. The interesting part is that when I am in callout view everything displays properly.
If the shape of the callout is rectangular, there is no problem.
Example - rectangular callout shape placed on sheet
Example - non rectangular callout placed on sheet
ennujozlagam
hi, check your view range in the call out view. thanks
That was the first thing i checked - it is not that 🙂
When I am in a callout view, things display properly irrespective of the shape of the callout. It is when i place that view on a sheet the view content disappear 😞
ennujozlagam
i tried it looks fine see attached. have you try to untick your graphics/use hardware accelaration?
ennujozlagam
The hardware acceleration did not make a difference but I turned off the room interior fill and that make it work. It looks like there is a bug in the system 🙂
ennujozlagam
ok. thats good....close the issue..
