Revit may use different terms to describe this. I am trying to create a wainscot panel with no moldings as seen in this render. Models are from 3dsky, room and panelling were created in chief architect and imported into 3ds max. Render was done in corona render.
Solved by se.ha. Go to Solution.
There is however a top molding and a floor molding. How would I create this wainscot panel.
Hi @bkjernisted,
does it have to be a "subtract geometry"?
Why not create a grid consisting of the horizontal and vertical elements "encasing" the voids?
Simply lock the horizontal and outer vertical elements to the reference lines and then create an array with the desired distance to create the inner vertical elements.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
You can use Railing, Curtain wall, or Wall sweep tool.
Toan Nguyen
You can create an array of voids. Try this method:
Gelöst: Re: array cut with void - Autodesk Community - Revit Products
se.ha
