I am trying to use the Bluebeam plotter with the PUBLISH command in Revit and nothing seems to be working the way I'm used to PUBLISH working, it's as though PUBLISH and Bluebeam won't talk to each other.
The Bluebeam plotter won't put the PDF's printed into the specified location within the PUBLISH dialogue box and the 'Publish to:' command won't work with 'PDF' selected so I can't plot multi-sheet files.
Is there a simple fix?
Thanks!
