Trying to sweep extrude an object but the end result is crooked. I created multiple structural floors and modified the sub elements to create my sloped surfaces and used the pick 3d edges. The extrusion works fine on the initial straight piece. I need the object I'm trying to extrude to be standing up. The sloped and curved surface tilts it. I'm new to sweeps.
Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Not sure without editing the revit file, but--
Try setting the Workplane of the Profile that you are using to create the sweep, to be perpendicular to the Path.
Use Show workplane to see a grid/plane of where it is set.
This seemed to work. I used the regular sweep for the straight pieces and used the sweep blend for the sloped curved surface. I then used the edges of the straight pieces as my 2 profiles for the blend.
Thanks!
