BIM levels explained
The concept of ‘BIM levels’ (and ‘BIM level 2 compliance’) has become the ‘accepted’ definition of what criteria are required to be deemed BIM-compliant, by seeing the adoption process as the next steps in a journey that has taken the industry from the drawing board to the computer and, ultimately, into the digital age.
The government has recognized that the process of moving the construction industry to ‘full’ collaborative working will be progressive, with distinct and recognizable milestones being defined within that process, in the form of ‘levels’. These have been defined within a range from 0 to 3, and, whilst there is some debate about the exact meaning of each level, the broad concept is as follows:
Level 0 BIM
In its simplest form, level 0 effectively means no collaboration. 2D CAD drafting only is utilized, mainly for Production Information (RIBA Plan of Work 2013 stage 4). Output and distribution is via paper or electronic prints, or a mixture of both. The majority of the industry is already well ahead of this now (source: NBS National BIM Report 2014).
Level 1 BIM
This typically comprises a mixture of 3D CAD for concept work, and 2D for drafting of statutory approval documentation and Production Information. CAD standards are managed to BS 1192:2007, and electronic sharing of data is carried out from a common data environment (CDE), often managed by the contractor. This is the level at which many organizations are currently operating, although there is no collaboration between different disciplines – each publishes and maintains its own data.
Level 2 BIM
This is distinguished by collaborative working – all parties use their own 3D CAD models, but not necessarily working on a single, shared model. The collaboration comes in the form of how the information is exchanged between different parties – and is the crucial aspect of this level. Design information is shared through a common file format, which enables any organization to be able to combine that data with their own in order to make a federated BIM model, and to carry out interrogative checks on it. Hence any CAD software that each party used must be capable of exporting to one of the common file formats such as IFC (Industry Foundation Class) or COBie (Construction Operations Building Information Exchange). This is the method of working that has been set as a minimum target by the UK government for all work on public-sector work, by 2016.
Level 3 BIM
Currently seen as the Holy Grail, this represents full collaboration between all disciplines by means of using a single, shared project model which is held in a centralized repository. All parties can access and modify that same model, and the benefit is that it removes the final layer of risk for conflicting information. This is known as ‘Open BIM’, and the UK government’s target date for public-sector working is 2019? Current nervousness in the industry around issues such as copyright and liability are intended to be resolved – the former by means of robust appointment documents and software originator/read/write permissions, and the latter by shared-risk procurement routes such as partnering. The CIC BIM Protocol makes provision for these.
chrisplyler
Please elaborate on the phrase, "The government has recognised...."
Who has created these definitions? Are they intended to be developed into some standard?
Architectbhus, In future, it is appropriate to reference where you are copying your material from or indicate credit to the original author.
This post has been copied and pasted from the NBS website.
http://www.thenbs.com/topics/bim/articles/bim-levels-explained.asp
I agree, this was what I read on the mentioned website of NBS and found very useful, thought of sharing it on this forum. Reference : http://www.thenbs.com/topics/bim/articles/bim-levels-explained.asp
