Thinner roof at gabels
Hi, I'm struggling with creating a thinner end on gable roofs. I have the normal roof surface to
the inside of the end wall and then a thinner roof over the gable which I associate with the
normal surface. Is it possible to remove the line in the joint between the surfaces? Or is there a better way to achieve a roof with thinner end projections ?
Thomas
constantin.stroescu
and the method I prefere to use in such a case:
Constantin Stroescu
JBGYDE
THANK YOU!
