How to create custom design wall with edit type properties
sfashah
Message 1 of 12
sfashah
Dear Guys,
i have a problem to create a custom wall in revit Family the problem is that shape of wall is different . Because My building structures want this type of wall. The Problem is that i create wall in revit family with the help of Extruision tool . Wall Look fine according to my shape. But the problem is Edit type properties are not visible so i cant add parameter in this shape. Please Help how to add parameter in this shape.
Replies (11)
Message 2 of 12
If I understand your question correctly, To add parameters, you need to be in the family editor, whereas you are currently in your project.
Simply click 'edit family' on your ribbon, once you have selected the family.
Message 3 of 12
sfashah
thanks ,  another problem is: edit family option is not visible. see attachment
Message 4 of 12
I can see it in your first image.
That right click menu is not the ribbon. The ribbon is at the top of your interface. Specifically, it is in the contextual ribbon highlighting green. See revit help menu for interface description.
Message 5 of 12
sfashah
how to create this type of wall with all parameters
i want this type of properties in above shape
i am share my shape files .Please hElp
Message 6 of 12
I don't understand, why do you need parameters for this? Isn't it a once off custom family? You could simply create an inplace component in the project environment rather than creating a family. You can use this tool...  this will give you the control you seem to be looking for.
Trying to put parameters on the family you posted would be very cumbersome.
Message 7 of 12
chrisplyler
You want all of the System Family parameters for Walls to be available for your custom family?
This is not possible. A Revit Wall has certain logical requirements that your custom family cannot meet. If you want the standard Revit Wall parameters, you will have to build it in the Project using the Revit Wall tools.
Message 8 of 12
I fail to see anything special with your wall rather than a bunch of walls with different thickness.  So, you can create several different wall types that match the intended dimensions and lay them out on your plan.  make them clean up nicely and you will have the exact same thing.
Message 9 of 12
sfashah
thanks .. i will try...  Smiley Happy
Can you give me your skype id if possible..
Message 10 of 12
L.Maas
ToanDN is right. You should probably make this from regular walls.
From the question I guess that you just started with Revit. Revit works different from other CAD software, like Autocad. If you are going to spend chunk of money on a piece of software like this I would advise some training. While the forums are good for solving specific problems/tasks an extensive training course through the forums is not really suitable. Take some basic training (i.e. books, video courses, classroom) and you will be up and running much faster. The concepts of Revit will become clear and doing a project will go much smoother.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 11 of 12
sfashah
Message 12 of 12
L.Maas
No, not really. Old fashioned...more a book guy myself.
However there are video courses from companies like infiniteskills or lynda.
Books, titles like the mastering series are good.
Classical, contact your/an Autodesk office in your area.
Louis
